This generator has been sitting for about 8 yrs in a rv housing, i will say it looks in very good condition. With that being said there are issue's first starting with myself, getting older and i am starting to lose my enthusiam for job's of this nature. So i will try to post here looking for short cut's...perhaps insight to what i am truly facing.
Issue's it will not crank period.
1. Soaking the cylinder's in SeaFoam& Mystery oil for a week now. New oil&filter.
2. New battery 750 cranking amp fully charged, solenoid one click's only,so far i have used the rv wiring to start all connection's cleaned no luck, then a direct battery to solenoid connection no luck. Then i applied a charger with a starting funtion about 50 amps in start mode...no luck no heat in the solenoid nothing no light buzz heard from any kind of amperage draw and never a large arc occuring from
3.The fuel pump is no longer functional simply just a loud banging noise, it has been unhooked the entire time any starting attempt's.
4. Im quite convinced it a solenoind yet solenoid's dont go bad from just sitting there...i think.
With all that being said ive taken the time to look at some manuals, it seem's there is the matter of the brushes, valves etc etc. With all this being said i know it has to come out of the dog house for a complete service so be it.
The thing that i need is to get it to turn over or crank at least, it has bothered me i never once experienced a arc of any substance in searching for a ground. Is there any type of circut in this system that will overide the starting circut...aka fuel sensor oil sensor load sensor etc etc. Along with that i cannot see a way to maually crank the engine/generator by hand without pulling it out.
Ok i get im lazy...any insight's here...Ive never ran into a situation where i could not get a engine to at least make a grunt...speaking of that is there a way to short the starter solenoid if that's even possible input or thought's.
Model No. 6.5NH 3CR/16004P
Serial No. J823633181
